Hey Guys I downloaded a regular avi format video. When I encode with TmpgEnc it's only audio and a black screen for video...I have divx codecs and players. I also have the patches, etc. Can anyone tell me what I might be doing wrong?
Results 1 to 9 of 9
I'm having the same problem. I used TMPGenc to convert AVI to MPG and when i went to convert a file tonight, it was just a black screen during conversion. I used vdub to extract the audio first then tried to convert using TMPGenc but it was a no go. Could it be because when i opened the program tonight, i got the message that said that the program was expired? Does this cause it to be useless?
Traci
Specs:
OS: XP Home
RAM: 512
HD: 80 Gig
Processor: Pentium 4/2.0 GHz -
The black screen usually means the Direct Show Priority was not set to be the highest in the Environmental Settings. The expiration of MPGEnc only disables the MPEG-2 functions. If you still want to convert MPEG-1, you can still do so.
Hello. -
What should the environmental settings be set on? And also, would there be much of a noticable difference in the way files are converted to vcd format if you can't convert to mpeg2. I'm not sure what the difference is between mpeg1 and 2 so i don't know what to look for.
Thanks for the help.Traci
Specs:
OS: XP Home
RAM: 512
HD: 80 Gig
Quality wise, at the same settings (resolution and bitrate) there's almost no difference between mpeg1 and mpeg2. The VCD standard uses mpeg1 with resolution and bitrates considerably lower then the SVCD standard which uses mpeg2. If you're used to SVCD then you might be disappointed with VCD. It is possible to go outside of the VCD standards to get better quality, but compatability with set top DVD players will be questionable. Try it, you might find VCD acceptable. If you don't, then consider buying TMPGEnc, it's reasonable.Originally Posted by ladytron68
Check the Glossary and What Is sections for definitions of mpeg1/2 and different video standards.
8)
"Art is making something out of nothing and selling it." - Frank Zappa -
i hav e the same prolems now
first it started with that tmpgence doesnt add al the subs now
the screen stays black ......AAAAAAAAAAAAAHHH
settings evrything set to 1
except direct show 2 -
heee maybe this will help
i had vobsub 2.13 i just upgrade it to 2.16 and now the black screen is a
gone -
Thanks. I'll have to check it out when i get home from work. I'll post back to let you know what happens.
Traci
Specs:
OS: XP Home
RAM: 512
HD: 80 Gig
TMPGEnc Video Organizer
By TBoneit in forum EditingReplies: 8Last Post: 14th Dec 2012, 20:28 -
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
Any way to keep TMPGEnc Author 4 from Re-Encoding video ?
By RWANDREWS in forum Authoring (DVD)Replies: 7Last Post: 3rd Mar 2009, 10:43 -
Converting Video for a Blackberry using TMPGEnc
By Vachoen in forum Video ConversionReplies: 3Last Post: 9th May 2008, 16:06 -
Text Over Video with TMPGEnc 4.0 Xpress?
By codeseven in forum EditingReplies: 1Last Post: 12th Apr 2008, 15:17
