al right i encoded this DiVX file to svcd (in perfect sync) played fine on my computer, poped it into my apex ad-1200 and it would skip then within a second it would catch up with the frame. i kno its not the burn cuz i burned useing two diff proggs (nero and vcdeasy) and i used tmpenc. I also burned at x16, x4, x8 & x1 all the same prob. Today i went to my friends house to try this svcd out and it worked perfect no skipping at all.(its a samsung not sure wat model) So im a little ticked.
here is a pic with the options i chose wit tmpenc
P.S. Hope some1 can help me!
Results 1 to 10 of 10
2 things,
1. Have you tried using NTSC in 30 frame mode. I see you have chosen Film.
2. Some DVD players have problems with SVCD's Not all Apex's will play them in sync. My 1110w and 3201 player's play out of sync audio.
You might try different media. (different color on burn side) -
alright thnx, but the wierd thing is that i can play d/led svcds fine.
but ill try that, if any1 else has suggestions plz post them thnx -
Try a lower bitrate setting
/Mats -
yeah, i also have an apex ad-1200. i wouldnt go over 2000kbps EVER. It's just not healthy.
Bravoxena -
it just encoded an svcd and it arrears to slow down and catch up every minute or so. probably because the player is so cheap. i was at 1950kbps. so far, my best encoded movie was a signs dvd rip.
Bravoxena -
yea 1950 kbps is mint it works like a charm, no slow downs perfect sync beautiful.
thnx to every1 that replied!
FLV won't play correctly in another computer
By kfain in forum Video ConversionReplies: 6Last Post: 29th Dec 2011, 12:10 -
DV won't play correctly anymore.
By xtremeD63 in forum Software PlayingReplies: 52Last Post: 9th Apr 2011, 13:08 -
How do I get 16:9 DVD video to play correctly on my 4:3 (regular) TV?
By chaacmool in forum Authoring (DVD)Replies: 1Last Post: 7th Oct 2009, 13:46 -
Some Videos Do Not Play Correctly
By DJboutit in forum Software PlayingReplies: 5Last Post: 10th Jun 2008, 21:20 -
DVD player that will play Divx correctly.
By ThaDraGun in forum DVD & Blu-ray PlayersReplies: 6Last Post: 15th Oct 2007, 07:59
