Hi!
I'm have tried to calculate the video bitrate my self, but I did not get the exact filesize I expected. This is how I calculate the video bitrate.
Let's say I want a 700MB file. This is what I do to find out what video bitrate I should use to get the best quality.
Desired File Size : 700MB
Video Length : 119 Minutes
Amount of CD's/files : 1CD
700MB * 1048756 = 734003200 bytes
734003200 bytes * 8 = 5872025600 bits
119min * 60 = 7140 seconds
5872025600 bits / 7140 = 822412,5490196078 bits
822412,5490196078 bits / 1000 = 822,4125490196078 kbit
822,4125490196078 kbit - 160 kbit = 662,4125490196078 kbit
822,4125490196078 kbit - 128 kbit = 694,4125490196078 kbit
The Video Bitrate should be 662 kbit/s if I have the Audio Bitrate set to 160 kbit/s.
The Video Bitrate should be 694 kbit/s if I have the Audio Bitrate set to 128 kbit/s.
I tried to use this method on one of my DVD's, and I thought I would get exactly the filesize I wanted, but no! The filesize became 713,8MB (748511038 bytes) and not 700MB as expected.
What can I do to calculate the exact file size? What else do I have to consider then this calculation which should be right ? Please help me...! I'm soon going to release a DVD Rip tutorial (I will post the link to my DVD-rip tutorial here in this forum this week)!
Thomas - MacFreak
It depends what divx,xvid or other codecs or encoders you are using.
Divx 3.xx assumes that 1 kbit = 1024 bits.
Divx 4+(and probably also xvid) assumes that 1 kbit=1000 bits.
Most encoders and codecs uses 1 kbit=1000 bits.
Calculating Proper Scale According to Aspect
By WARnux in forum Software PlayingReplies: 6Last Post: 24th Jul 2010, 07:41 -
Calculating letterbox in AVS
By AlanHK in forum Video ConversionReplies: 5Last Post: 26th Oct 2009, 04:50 -
Am I calculating resolution correctly?
By alcOre in forum Newbie / General discussionsReplies: 2Last Post: 24th Sep 2009, 07:37 -
Calculating Video Length
By scan in forum Newbie / General discussionsReplies: 3Last Post: 1st Nov 2008, 12:33 -
Calculating a bit rate
By haile in forum Newbie / General discussionsReplies: 5Last Post: 30th Apr 2008, 08:03
