  1. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    I've created a few home-made DVD, but the problem is that the frame size is too large for the TV. I start with an uncompressed (Huffy) AVI and encode with TMPGenc @ 720x480 (using the DVD NTSC template). When I play it back, about 20-50 pixels get cut off all around the screen. Say for example it was a video from MTV.
    If it was titled*:
    Britney Spears
    "Oops, I did it again"
    It would show up as:
    ney Spears
    s, I did it again"
    Is there any way to maybe put a border around the video so that the TV will clip blank space, rather than the video? I know that there are crop and resize options in VDUB and TMPG, but I don't think those will work in this case.
    *I don't actually have any Britney videos. That's just for example.
  2. Member spidey's Avatar
    Apr 2001
    U.S.A.
    There is a clips size filter in TMPG
    You may want to frame serve and re-encode to add / adjust the borders using avisynth and CCE
    or
    VirtualDub (see under Video / Filters) into TMPG
    Either way you look at it, unfortunately, if it cut that off on your Mpg encoded version, you will have to re-encode the source.
    ~~~Spidey~~~
    "Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
