I am currently using DVD Maestro for authoring, but I would like to try Scenarist and DVD Workshop. Has anyone used all 3, and how did they compare? Thanks.
Hmmmmm.....
Well first off I'd say fairly safely, that Ulead is not even in the same realm as the 2 sonic/spuce ones.
A big advantage Scenarist has over Maestro is that it will allow 480x480 resolution, so you can incorporate your old SVCD streams without re-encoding. However, it seems to be far more complex of a program.
I would recommend viewing the guides at doom9.org and then thinking if it's what you'd want to pursue. I know Doom knows his stuff far more than I ever could, and after I saw his comment of frustration as to some parts of it,....
I said DVD Producer (a more modern gui and updated version of Maestro by Sonic) and Maestro work just fine by me
~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
A decent substitute for DVD Maestro
By Drakul in forum Authoring (DVD)Replies: 12Last Post: 8th Mar 2012, 22:11 -
DVD Maestro Entry Point Not Found Error
By criver in forum Authoring (DVD)Replies: 7Last Post: 9th Aug 2011, 12:42 -
DVD Maestro - Multiple assets, one VTS
By alfini in forum Authoring (DVD)Replies: 0Last Post: 10th Nov 2010, 02:32 -
DVD Maestro Compilation error
By MJPro-Tester in forum Authoring (DVD)Replies: 1Last Post: 21st Apr 2010, 04:22 -
Help! DVD Maestro RealTime preview. Cinemaster not working.
By IJM in forum Authoring (DVD)Replies: 10Last Post: 1st Jan 2009, 04:22
