8)
Thank you in advance! I am very new to DVD burning. I used the demo version of Ulead MovieFactory 2 to convert an XVID movie to mpeg2 to burn onto a DVD-r. When finished converting, the VIDEO_TS folder ended up 4.6gigs and Nero is telling me that it will not fit on my 4.7gig dvd-r. In fact, Nero says I can only burn up to 4.3gig on these discs. Does DVD-R really require 300mb's for formatting?
Also, I have tried TMPGenc, but it gives me memory errors. After some research, I decided to try CCE. I have purchased the pro version, but what now? I have been looking for a detailed tutorial on how to use CCE but I haven't had much luck. Which program should I use with these codec? Any links to good CCE tutorials (preferably for use with a freeware program).
Thank you so much for taking the time to help!!
1. Does Nero really need 300mb for formatting?
2. Any links to usind CCE and an authoring program?
No, there is no 300 MB of formatting. 4,700,000 bytes is equal to 4.3 GB (it's 1000x1000 versus the true 1024x1024). Remember that 1 MB is eqal to 1,048,576 bytes, not 1,000,000.
CCE is an excellant program. Most guides will work for CCE or TMPG, and both work well. However, CCE is not point and click. Check teh guides again.To Be, Or, Not To Be, That, Is The Gazorgan Plan
Newbie conversion help
By chiller15 in forum Video ConversionReplies: 2Last Post: 7th Apr 2010, 08:41 -
sync issues with DVD to DivX conversion
By snafubaby in forum DVD RippingReplies: 12Last Post: 24th Dec 2008, 03:10 -
Newbie post - Recommendations for VHS-DVD Conversion.
By Mysticle31 in forum RestorationReplies: 20Last Post: 8th Jul 2008, 01:51 -
DivX to Mpeg -> DVD Conversion is Jerky
By jedijfo in forum Video ConversionReplies: 4Last Post: 15th Oct 2007, 09:32 -
DVD to Divx conversion - Problem with audio ! Please Help
By sharartie in forum DVD RippingReplies: 1Last Post: 23rd Aug 2007, 05:13
