I Try coverting a xvid to mpeg1. when i covert it i cant see any frames of the movie being converted in the preview window of TMPEGEnc 2.9. The movie converts into pink color or just blacks out and TMPEG crashes. I have the codecs for all of the files because i watch the movie 1st b4 i convert it.
need help please....
yea me 2 i try to convert a Xvid video file which is basically .avi and it crashes as soon as i start in TMPG-enc
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!
Ughhhh, doesn't anyone search anymore? Under enviromental variables up your FFDSHOW setting to 3 and bump everything else down to 0 or less. Also, get the 4cc changer and change your XviD to read divx/divx for video/audio.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Gaz, would that also help with a PitA XviD file that's showing up alternately as 23.976 in virtualdub and 29.97 in WMP when it's actually shown to be 30.000 in TMPGEnc and the extracted audio?
Totally threw off my transcoding to PAL (was expecting a speedup 23.976 - 25.000 but instead... 30 down to 25) but got a handle on it now... used inverse telecine simultaneously with a non-conversion at 25fps, and modified sound conversion parameters.
Still very cheeky though and dont want to have to deal with that again
"XviD - our quality's quite good but we guarantee to cause you headaches"-= She sez there's ants in the carpet, dirty little monsters! =-
Back after a long time away, mainly because I now need to start making up vidcapped DVDRs for work and I haven't a clue where to start any more!
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 13:23 -
Converting Xvid to MPEG1(VCD)
By Ensign in forum Video ConversionReplies: 3Last Post: 18th Dec 2008, 16:00 -
best avi (divx/xvid) to cd-r (vcd) converter
By waefwaeefwaefw in forum Newbie / General discussionsReplies: 8Last Post: 15th Sep 2008, 13:36 -
How to convert VCD to Xvid (avi)
By nalika in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2008, 17:51 -
Vista beginner needs help with video conversion! Xvid to VCD with subs
By Joakim_A in forum Video ConversionReplies: 2Last Post: 23rd Sep 2007, 03:59
