hi am useing mainconcept encoder to encode movies from avi to mpeg 2 it working good and its fast my prob is i want to put more than one film on to a dvd and att he min the films are coming out 2.95 and 3,29 gig to big for a blank dvd does anyone know the settings to change to make it smaller thank you
You would begin by looking under TOOLS for a bitrate calculator - this will help you figure your bandwidths
As far as adjusting the MC encoder, I do not know how and what to adjust as I do not use it, but you would most likely want to adjust your encoding parameters per the bitrate calc's values.~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
