I dont know wot Ive done I changed the Envorontental setting and know when I try to encode it sais "cannot open audio source"
please help
Personally I leave the enviromental settings at their defaults...and don't have any problems. If you want to reset the settings to their defaults, but you can't remember what the defaults are, then the easiest way to do that is to delete the TMPGenc folder and either un-zip it again from the original zipped folder if you still have it, or redownload it again if you don't.
*tip*
I keep the original zipped folder in a safe place...that way if I ever accidentally change a setting its easy to just delete TMPGenc and then reinstall a fresh copy from the zipped folder.
