I ve tried to capture thru ieee1394 with my camcorder, using neodvd. I can only get avi format, which you must convert to mpg before writing to vcd and it takes forever. What software can I capture with ieee1394 to mpg straight.
Thanks![]()
Is your source digital or analog?
I think you want to look into getting a realtime capture card if you have a digital source. Otherwise, I believe something like Ulead Video Studio will allow you to capture in vcd(mpeg).
HTH,
D -
WHAT HE ASKED:
I ASK TOO:
does anyone KNOW OF SOFTWARE THAT CAPTURES TO
mpeg-2 thru the firewire? -
yes, i found out the NEODVD can capture from ieee1394 to mpeg1 or 2 in real time. Out of my 40 minutes of movie, the first 5 is good, the rest sorta skip. Is this due to my ram capacity of only 128Mb, or my video card? I think I should upgrade my ram to another 512Mb, any ideas?
I suspect that it is a combination of RAM and CPU speed... could be other bottlenecks too of course.
For example I had no problems doing what you want to do on a P4 2.0 Ghz w/512Memory, 7200 hard drives.
If you only have one drive it could be as simple a problem as the fact that you are capturing to the same drive the OS is on. Capturint to the same drive as a swap file is on is a problem.
CVapturing to MPG format with software like you are trying to do is very cpu intensive as it must compress in real time.
I broke down and bought after trying CCE Basic to encode my AVI captures as that way I can get better quality than real time encoding.
But it depends on the source. a clean digital signal (Sat TV, Digital Cable, & DV Camcorder) are easier to encode than a Videotape capture. The noise and the head switching from the vcr can cause problems.
So in essence More info could be helpfull.
Good Luck
Roger -
I'll do a test cause my friend has NEO 4.0
If I can thursday to keep this thread alive
ANYONE ELSE?
I can't use my fastest machine but I.ll try it on the Abit with 1.6p4 at 1.2GIG SDRAM 133 using the SIIG FIREWIRE CARD
IEE1394 DIRECT TO MPEG 2
does neo let you set any characteritics of the I-Frames or GOP structure or is it basically one setting?
Ieee1394
By Kevintucky in forum Newbie / General discussionsReplies: 2Last Post: 30th May 2011, 16:32 -
Burning several mpg files straight to a DVD compliant disk...
By vonsworld in forum Authoring (DVD)Replies: 2Last Post: 5th Dec 2010, 06:25 -
Sony camcorder HDV tape to iMac with iLink ieee1394 cable
By Rossbo in forum MacReplies: 6Last Post: 1st Feb 2010, 19:46 -
miniDV player with IEEE1394 Firewire OUT (?)
By jimcornetet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 30th Dec 2007, 23:34 -
Transfer data code while dubbing miniDV -> DVD+R using IEEE1394/iLink
By alokeprasad in forum Authoring (DVD)Replies: 0Last Post: 24th Dec 2007, 08:25
