I read somewhere, that when You set up in TMPGenc (to convert an avi file to mpg(svcd)), that You should "unlock" - under extra - before starting the conversion.
If I do that, the buttons on front are available. I take it that I should then select like "System (video/audio)".
But then - according to the instruction - I should also load the correct value, like "SuperVideo CD (Pal).mcf". But when I do that, the fore mentioned streaming options on the front greys out again. So the "unlock" is no more effective, as far as I can see.
What is the correct way of handling this?
Preben
Thanks -
Ps. -
Do it the other way round! Load the unlock.mcf AFTER loading the required template for (S)VCD.
Okay - whats it for anyway? Is it just a matter of how You watch the video on Your screen while working on it - and therefore has nothing to do and no influence on the result of the conversion?
Thanks -
Ps. -
When you use the SuperVCD template, as you say most settings are locked. By then loading the unlock template, you unlock all locked settings, allowing you to modify bitrates, resolutions... Everything. This may cause the mpeg to be not suitable for SVCD, but as said, allows you to do tweaks, hopefully within the specs, and, most important, within what your player can handle!´
/Mats
What settings for converting videos for rtsp (Darwin streaming server)?
By sunnyboy88 in forum Video ConversionReplies: 7Last Post: 2nd Nov 2010, 11:00 -
Flv streaming from my site stutters on some computers Here are my settings
By doz in forum Video Streaming DownloadingReplies: 2Last Post: 16th Nov 2009, 12:09 -
Optimal Settings for WMP Streaming Video
By john_doe1 in forum Video Streaming DownloadingReplies: 9Last Post: 24th Sep 2009, 18:12 -
Ripping HD DVDs to streaming MP4 - Best settings for Quality?
By martymars in forum Blu-ray RippingReplies: 15Last Post: 23rd Sep 2009, 15:53 -
Basic web streaming settings for my website.
By thurnau in forum Video Streaming DownloadingReplies: 5Last Post: 24th Jun 2009, 02:10
