I currently use Adobe Premiere 6.5 to capture avi files through Canopus ADVC-100. Which software can I use if I want to capture directly into mpeg-1 and mpeg-2?
Software:
Adobe Premiere Pro - capture stills & motion, edit, render
Adobe Photoshop 7.0 - edit stills
TMPGenc Plus 2.5 - encoding, splitting mpeg
VCDEasy 1.1.5 - stills to mpeg, interactive menu, SVCD cue/bin
MOTV 2.10
Nero 5.5.8.2 - burn image -
Hi.
You can use Ulead's softwares like Video Studio and Media Sudio, or Movie Factory. But the quality is not good like when you capture to DV than convert to Mpeg. And it requires fast CPU. BB. -
Hi Tony,
Thanks for the advice. Do you know whether there are any conflicts between Ulead and Adobe? I'll like to check on it before installing any other capture software.
Thanks again
Halley
SingaporeSoftware:
MOTV 2.10
Easycap software to capture mpeg 1/2
By visionman in forum Capturing and VCRReplies: 2Last Post: 16th Sep 2010, 11:04 -
canopus advc100 problems--any suggestions?
By esek64 in forum Video ConversionReplies: 3Last Post: 14th Aug 2010, 04:26 -
What software will capture MPEG-1 ?
By Palmer Eldritch in forum Capturing and VCRReplies: 17Last Post: 4th Jan 2010, 19:12 -
MPEG capture software recommendations for WinTV HVR 1850
By justin81 in forum Capturing and VCRReplies: 0Last Post: 23rd Jul 2009, 10:38 -
Capture Software for VHS to MPEG/AVI
By quantass in forum Capturing and VCRReplies: 1Last Post: 7th Sep 2007, 15:22
