I have recently started using main concept , as some movies I had I could not extract the audio with virtual dub to use with TPMG.........the first few movies i encoded with MainConcept were fine , but now It freezes on a frame carries on encoding , you can hear the sound fine ...any one else had this prob and now how to fix it ?
thanks in advanve
Results 1 to 21 of 21
ok I got rid of directx 9 and re installed 8.1 but the picture still freezes someone must be able to help
You need to give us a little more to go on:
- What is the source?
- What authoring program?
- Does it freeze on a standalone player or the PC?
- Beginning of the movie or end of the movie?
- Does it always freeze at the same spot?
- Did you do editing on this movie? What program? -
it freezes at the same point everytime it encodes any avi.......near the end of the file.no editing..im on win xp pro using mainconcept mpegconverter
Have you tried to load the AVI into VirtualDub and done a search for bad frames?
I notice something the other day. Check this out first input the source file than look at the video input time and the audio input time you should see a different in 10min or so. I notice this lets say the movie is 50 movies right when u input the file Mainconcept notices the video as 40 mins and the audion 50 mins. Thats why the video freezes before the audio. Now how do we fix this beats me.
This anomaly seems to occur on mpegs encoded at 23 fps--never encountered a problem at a true 25 of 29 fps.
No luck the video still freezes with 10 mins left in the movies the Audio continues
What program do you use do you use to burn the mpegs produced by mainconcept?
This is so much fun! -
I'm trying to encode SVCD to VCD but like I said check your input video time with you audio time ur going to see a 10 min different
I have had this problem b4. I dunno how to fix it. i just switch encoders
I get that when the files are corrupt. Either recapture it or try to defrag the HD. It may be on a bad spot on the drive or fragmented
Hi soul67uk,
I use MainConcept all the time with no problems but I did have problems with Main Actor when it came out. This was due to DirectX 9 and after contact with them they quickly produced a patch to overcome this. My suggestion is to contact their support either by phone or email for in my experience they want to help and do quickly. It is a great encoder and I have tried most and all input will help make it even better.
Lastly I have always been told you cannot step back with DirectX to a previous version so are you sure you did remove it?Take care
Dave
Dave Knowles Films
Southampton - UK -
I've seen this difference between audio/video lengths.
try loading separately into mainconcept and use different import modules
I load video with avi source and audio with direct show and this cures it.
main concept's cuda encoder released to public
By deadrats in forum Video ConversionReplies: 1Last Post: 17th Oct 2010, 19:33 -
Main Concept Pro HD4 work in CS5?
By darkztk in forum EditingReplies: 2Last Post: 6th Aug 2010, 23:00 -
main concept gains gpu accelerated encoding
By deadrats in forum Latest Video NewsReplies: 0Last Post: 5th Jun 2010, 16:19 -
Backup main movie from DVD9 to DVD5 with main & chapter menu's.
By ChibiTomo in forum User guidesReplies: 18Last Post: 18th Jan 2010, 19:27 -
main concept no audio source
By petemacc in forum Newbie / General discussionsReplies: 4Last Post: 27th Aug 2007, 15:22
