Hi there...
I just received a bootleg music dvd-r from a friend. This dvd has some damaged audio segments (the video is fine). Now, i purchased a long time ago the same concert on CD, and now that i found the dvd has errors, i wanna use the video from the dvd with the audio from the CD. My idea was rip the dvd, use the dvd2avi & replace the wav file that this program create with the ripped wav from the cd (previous editing with Sound Forge). After use tmpegenc to re-econde the files and burn....is this possible??? The image will deteriorate if i re-encode at the same resolution (720x480) the video file???
Or do you know a better way to replace the audio without touch the video quality of a dvd...
Please help friends...
Big Saludos from Guadalajara, Mexico
Chances are the audio would go out of sync if you just place the entire audio track with the Video.
You could edit and create individual videos for each tune.
The video should still look pretty good after ripping and re-editing. I've done it with some home movies that I wanted to re-edit.
What is the easiest way to add or replace existing audio DVD sound track
By pwangdel in forum Authoring (DVD)Replies: 18Last Post: 2nd May 2011, 02:10 -
Replace audio on a DVD
By danielmak in forum MacReplies: 7Last Post: 31st Oct 2010, 23:40 -
I need an easy way to replace audio tracks in a DVD
By sanguino2001 in forum Authoring (DVD)Replies: 6Last Post: 2nd Aug 2009, 13:00 -
How do I replace audio in MPEG2 (DVD) files using Freeware?
By semmel in forum EditingReplies: 2Last Post: 28th Sep 2008, 21:16 -
replace audio track in retail DVD
By foolosophy in forum AudioReplies: 7Last Post: 2nd Aug 2008, 19:04
