I made an MPEG-2 (SVCD) file using TMPGEnc. I had to extract the sound from the file using VirtualDub. It worked great for the the first CD I made. I had to make into 2 CD's since it was to large. I did the same for the 2nd file and it didn't work. No sound what so ever. I checed the wav file and there is sound so I know that isn't the problem. I also went back and made short clips from the 1st part of the file which work fine. I tried the same (making short test clips) from where the 2nd CD should begin at and I still get no sound. Any clues??..
Veshaln![]()
Results 1 to 1 of 1
Audio has problems in Windows Media Player but not in other audio apps
By brassplyer in forum Software PlayingReplies: 7Last Post: 23rd Sep 2011, 16:12 -
TMPGEnc Authoring Works 4 problems...
By gonzalo76 in forum Authoring (DVD)Replies: 7Last Post: 12th Oct 2010, 01:59 -
Problems with TMPGEnc...
By SolsBBQ in forum Video ConversionReplies: 5Last Post: 3rd Jan 2009, 06:00 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 18:37 -
By maccool111 in forum ComputerReplies: 3Last Post: 23rd Jul 2007, 16:47
