    Baltimore, Maryland
    Ok i have a problem.
    I follow the guides on SVCD2DVDMPG and no matter what i do the file is always outta sync rather it be VCD or SVCD and if i demux the audio in or out of the program here is what i do.
    Load up my folder with my .bin
    turn off the remove intermediate files
    go to in/out and choose "BIN->ES"
    go to Res Patch and pick "720" and "entire file"
    than start and all the programs do what they do and than i author
    the dvd in Ifoedit wait till its done than delete the .ifo and stuff it makes
    than rename the .vob files to 01 and 02 (one for each svcd) than crete a new set of ifo in ifoedit than burn onto a dvd-rw and every time (done it for 5 movies so far) every one has be majorly outta sync.
    does anyone know what i am doing wrong to get my files insync?
    thanks for the help.
    [ = Check out my band @ www.samadhirock.com = ]
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    i-on-s: out of sync issues are not common but there are some people having them. I find it interesting that you have it with 5 DVDRs - most people are having 90%-ish success. So can you tell me if you play the DVD on your PC (WINDVD etc) from the VIDEO_TS folder - do you have sync issues? Have you got svcds to work at all with your setup, b4 svcd2dvdmpg?
    I notice you are patching the entire file. I have an update to svcd2dvdmpg which addresses a bug in this function. It might be that you could try that.
    CB
