After installing the Nimo codec lite package, my sound has never been the same![]()
(installed on both win98 and on win2000)
The sound is Jerky, Boxed-sound (when speakers have been damaged - when playing to loud).
The speakers are fully ok, I have tested them on another PC.
I have tried to uninstall, but that doens't help![]()
Also tried removing all the audio-items (in win98 and win2000) in control-panel, restarting the pc, and choosing new updated drivers downloaded from creative.europe.com... but STILL no good sound![]()
..help.
I can help. I used to get exactly the same thing as you described. here is what you need to do.
click on start/search, and type in ac3audio.ax
(its in the windows system32 folder)
move this file to a temp folder (I havent deleted mine, just in case something needs it. I just move it temporarily when Im listening to music, and move it back when im encoding etc..)
I dont know why this file causes this, maybe someone else knows? -
Thank you very much!
Solved the problem at once!!
Really appreciate the help!
The sound is back to normal now... remarable
Screwed over by a CODEC install
By AveEye in forum Newbie / General discussionsReplies: 1Last Post: 27th Jan 2012, 05:34 -
Virtualdub and K-Lite Codec Pack
By EdoScario90 in forum Video ConversionReplies: 9Last Post: 9th Dec 2010, 16:26 -
K lite codec pack
By Pumkinhead in forum Newbie / General discussionsReplies: 14Last Post: 26th Oct 2010, 14:12 -
K-Lite Codec for mac
By pixel zombie in forum MacReplies: 3Last Post: 9th Jun 2009, 04:25 -
Codec problems after installing k-lite
By woolf-gang in forum Software PlayingReplies: 9Last Post: 28th Sep 2007, 09:56
