CAN ANYONE HELP ME.. I have been burning at 2x for about a week or so with 2x media (white lable).but as of today i only get burn speeds of 1x..? with the same media..can anyone tell me whats going on.. thanks![]()
hmm, did you change firmware? apparently the 2.0e firmware makes the writer burn at 1x on 1x media whereas 1.0g firmware would allow 2x (not on all the media, but much like the pioneer hacked firmware kinda does)
no i have not touched the firmware.I am using the sme software and media...burning at 2x one day 1x the next.... can ANYONE HELP.
Iīve had the same problem, both dru500ax and about two weeks later start to burn at 1x the same media (sentinel) that i used to burn at 2x, but with one small difference, either burn at 1x or it simple give an error message at the middle of the writing and ruined the dvd, i both 10 dvdīs and it ruined 7 dvdīs, iīve update the firmware to 2.0e, and didnīt make any difference, then i moved the dru500ax to an old computer that i have with different os (win2k) and now i can burn at 2x, at least i tried one time and didnīt had problems.
Just to let anyone know that i changed my media to bulkpack 2x and every thing is fine.
Sony Optiarc DVD RW Drive writes but verify errors???
By bahjan in forum DVD & Blu-ray WritersReplies: 7Last Post: 6th Jan 2012, 09:33 -
BD-burner writes a BDR but data gets corrupted
By ma-fia in forum DVD & Blu-ray WritersReplies: 6Last Post: 5th Nov 2011, 18:00 -
BD-RE maximum writes?
By doppletwo in forum MediaReplies: 1Last Post: 8th Aug 2010, 23:59 -
DVD Burner sudenly read/writes at less than 1x speed
By Megahurts in forum ComputerReplies: 1Last Post: 22nd Apr 2009, 22:47 -
NEC ND-3520A writes DVD's, which it cannot read
By Ruut in forum Newbie / General discussionsReplies: 1Last Post: 24th Sep 2007, 13:36
