I've downloaded a couple of charmed episodes and now I would like to burn them and watch them on my tv. But the file I downloaded is *.mpg. Is this already a (s)vcd, and how do I check this?
And one other thing. I started to test a couple op things with TMPGEnc, but does it realy take about 3 hours to convert![]()
get bitrate viewer from the tools section and open your files in this (the free version has sufficient functionallity for what we need). Use the info this provides and compare it to the technical specs for (S)VCD as given under the WHATIS section to the right. All you really need to know are the framerate, resolution and bitrates.
Hoe this helps -
As I said, open your mpeg in bitrate viewer. If you open your eyes you will see a pane on the right of the graph display that gives you basic info like framerate and resolution. Bitrate is a little higher up also on the right. It will also tell you if it is mpeg-1 or mpeg-2. Now compare this info with the specs for VCD and SVCD to determine which one (if any) it is.
Get TMPEG. Click MPEG Tools, switch to the Demux tab, then load your MPEG. Before you execute the demux operation it will tell you whether your MPG is MPG1 or MPG2. (You don't need to demux it to determine this.)
However, just because it's either MPG1 or MPG2, that doesn't mean it's compatible with either SVCD or VCD. A good way to do that is to create an SVCD or VCD project in a burner app and then add the MPG clip to it. If the burner complains that it's not compliant then you need to reecode it so that it's compliant.
Playing Downloaded Video File.. Help!
By andrea121 in forum Newbie / General discussionsReplies: 4Last Post: 24th May 2010, 19:44 -
mpg won't stream until the entire thing is downloaded.
By flycast in forum Video Streaming DownloadingReplies: 1Last Post: 19th Dec 2009, 23:23 -
Can Video File Be Uploaded (file share) And Downloaded in PAL Country
By studioc in forum Video ConversionReplies: 9Last Post: 3rd Nov 2009, 15:34 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 17:56 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 18:52
