I just converted some Video files to MPEG using TMPGEnc. My CD burning software reads the newly converted files as Raw Data. I did an MPEG Check and it shows Video Stream, Audio Stream, and Video System Header as Yes, but it shows Audio System Header as no. I think that's why it says Raw Data. Does anyone know how to correct this?
Not unless you say what CD burning software you use. And have you tried VCDEasy?
Hello. -
I'm using B's Recorder Gold. No I haven't used VCDEasy. I assume that's a mpeg conversion software. I'll look it up.
thanx so much for making me download vcdeasy. I found the problem. Some parts were in PAL instead of NTSC and vcdeasy told me that. So on tmpgenc i just loaded the video cd ntsc template and everything's working fine =)
Why does your system have audio/video sync issues?
By Will Hay in forum Capturing and VCRReplies: 65Last Post: 15th Sep 2024, 01:15 -
Changing default audio in MKV header / Haali issue
By mrg155 in forum Newbie / General discussionsReplies: 0Last Post: 13th Jul 2011, 03:24 -
audio system for pc
By robinmishra in forum AudioReplies: 0Last Post: 28th Feb 2011, 09:26 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 19:40 -
Record Video+external audio-system audio
By DavidCasillas in forum MacReplies: 0Last Post: 11th Apr 2009, 03:36
