Is it possible to make a Mixed Mode CD that supports both Videos, as well as Audio?
I have a few "live" videos of a band I want to burn, as well as the audio tracks I ripped to .wav. Is there software that will allow me to create a CD that when I play it in my DVD player will play the VCD portion, and in my audio player, just the audio?
tb
Please, PLEASE search the forums. This has already been asked a number of times.
You can use NERO 5.5 or Easy Creator 4.05, I like NERO better. My son has doe one but have not got the auto load to work correct for the audio, video just fine.
Hi TimmyGUNZ,
WinOnCD 3.8 PE can do this.
There are 2 ways:
1 - Hybrid CD, VCD or SVCD with audio tracks like a normal CD
or
2 - Hybrid CD, VCD or SVCD with audio tracks in CDDA folder
it´s up to you.
If you want to know a step by step, e-mail me.
Regards,
Cardosi
