    Apr 2003
    Norway
    Hi!
    I have downloaded a DIVX-file and the picyre is perfect. However there is a problem with the sound- it doesn't work. Do anybody know how I can fix it? Is there maybe a program or something I can install?
    Well, I would be very greatful for your help!!!!
    Joanna
    jw
    You don't have to repost if you need to change your old post. Just click on EDIT on your post to change the subject or the post text. I deleted your other post.
    Use avicodec or gspot to identify what audio codecs you need to download
    www.dvdrhelp.com/play#identify
    Apr 2003
    Norway
    Hi!
    I downloaded AVIcodec, but what do I have to do now?
    I am not good at these things, so I am greatful if anyone helps me...thanks!
    Joanna
    jw
