Results 1 to 14 of 14
    Dec 2001
    Denmark
    Hi.
    I got this capture card called Terratec cinergy 600 TV.
    I use the program Windvr that came with it, to make vcd or svcd and maybe later DVD.
    In windvr under options, you can set how big the mpg file should be, before it's makes a new mpg file, default is 600 MB ( about 1 hour) in vcd mode.
    When i recorded 1 hour 30 minutes, there will be two mpg files, one is 600 MB and number two is about 300 MB.
    There is no problem with the first mpg file, the problem is mpg file 2,3,4 and so on.
    The mpg file 2,3,4 and so on can be played in mediaplayer, but if you want to take something out in the middle of the file, using TMPGEnc (merge and cut) it will say the file is bad, this is what it sayes "Illegal MPEG video stream".
    Pleaze help.
    What can i do.
    Dec 2001
    Denmark
    There must be someone out there with an answer.
    Come on.
    I have about 40 GB recording from tv and i can't use them, because i have to cut them.
  3. Come on, people, this is really a crappy situation we're in, we can't use the damn files... doesn't anyone care?
  4. I'm in the same boat. Capture in DVD format, and get 1 file 4.1 GB ib size, and the second, the remainder of the movie, unless it requires 3 or more files. I can trim or split the first part, but get the "Illegal" or "Not valid" error message. Someone suggested recording the first half, and then recording the second half. That's fine vor recording from tape, but I cap. from DSS. Not very practical, unless it's the PPV's.
    Oct 2000
    Ireland
    I also found that TMPGEnc demultiplexer fails from time to time (Illegal MPEG video stream).
    I then use demuxone.exe from DVMPEG Darim Vision.
    http://www.darvision.com/demo/dvmpeg6demo.exe
    It works perfectly.
    After that you can remux the audio and video in TMPGEnc which then has no problem demuxing or editing the file !
    hope this helps
    uteotw
    Dec 2001
    Denmark
    Sorry uteotw but your link dos'n work and it's ok, because i have just find a program that works and the program is VCDCutter.
    Thanx all for your help.
  7. I'm having a problem with TMPGenc's "Merge". I have 2 mpg files. You can watch the seperatly and they play fine. But when I merge them together. the second part of the movie's audio is out of sink. Anyone have a solution?
  8. Lost Will Hay's Avatar
    Oct 2002
    Buggleskelly Railway St.
    If any of you are trying to merge/cut whatever with TMPGEnc using a file NOT CREATED WITH TMPGENC, then you're wasting your time.
    The help files state there will be problems with .mpg's created with third party software.
    As an aside, those new to the forum should learn the value of patience, and the simple premise that if someone knows the answer they *will* assist, given time.
    W.
    tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
    Dec 2002
    You assume it's a complient MPEG stream? Several of the Personal Recorders are NOT complient.
    So try this, make the disk size 5000 and don't worry about it. Edit the stream as needed, then cut the finished product at whatever CDR breakpoint you use.
    Here's a tip; There is more than 1 type of MPEG stream. This has absolutely nothing to do with codecs, it has to do with the physical structure of the Audio/Video stream. Try de-multiplexing them before you edit them?
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  10. Originally Posted by Silky31
    W.
    Not entirely accurate. I've been capturing with a Dazzle in vcd format, and now with a TV@nywhere in VCD, SVCD, and DVD formats, and the only problem encountered is with DVD, but ONLY with the 2nd (3rd.) file. IE, the part(s) created after the first 4.1 Gb. is reached. Other than that problem, I can trim, split, demux, render, whatever.
    Mar 2002
    Milwaukee, WI USA
    if you have no problems with the first file can't you just set your capture software to create one big file and NOT split it, then do whatever you want with that ONE file in TMPGEnc?
  12. Hard drive not formatted to NTFS. Just dawned on me this morning why I couldn't exceed 4.1 Gb. Will be correcting that in the next couple days.
  13. Lost Will Hay's Avatar
    Oct 2002
    W.
    So, what do you use to encode before you use TMPGEnc to trim/merge etc.? and and another related subject...
    ...you're using TMPGEnc to render?
    Will
  14. Capture directly to DVD MPEG2 w/ TV@nywhere, trim and split in TMPEGEnc, then author and burn. I've only got a 12 year old JVC TV with one RCA imput (No SVHS), so quality is fine for me.All I need to do now is find out how to add chapters w/o screwing up my audio, and getting audio that will work with my 10 year old Surround Rcvr.
