i juss downloaded the movie friday after next and it plays fine and everything but there's no sound, i have xvid codec, and acdfilter or whatever in too?? how could i get the sound to work![]()
thanks alot
peace, love, and chicken greese :P
Newbe to the website and juss tryin to learn new stuff
Hi bober,
I had just the same problem as you do and I was browsing the forum for an answer. Since I didn't find one, I searched for info in some of the guides and I finally found a way to solve the problem.
I first installed some codecs found in the nimo pack (the ones I didn't install before) and that just made things worst. My media players always crashed. Finally I downloaded a program called AVIcodec which tells you what codecs are needed to play both the video and the audio. It also tells you if you have such codecs installed or not. Plus it has a link to a website where you can find the desired codec. In my case, I was missing AC3 DVM and I downloaded it here. You can also search for other codecshere .
Hope this helps
First post here and first time here (surround sound system help) Plz
By Izzdan in forum Newbie / General discussionsReplies: 1Last Post: 14th Aug 2010, 02:13 -
Help PLZ! subtitle problem.
By Ajimal in forum Newbie / General discussionsReplies: 2Last Post: 15th Feb 2010, 23:25 -
plz help
By sajjad223 in forum Video Streaming DownloadingReplies: 1Last Post: 4th May 2008, 11:12 -
VirtalDub ERROR - plz help
By UmmAddan in forum DVD RippingReplies: 3Last Post: 30th May 2007, 18:52 -
my PC stats plz help can i edit on this
By Kigi in forum ComputerReplies: 8Last Post: 30th May 2007, 03:30
