In captureing stuff to MPEG1 using my WinTV PVR, I get good quality files that play back correctly on my PC, but on my DVD player on TV they look like crap because the TV is interlaced and VCD is progressive. Is there any way to work around this problem?
MPEG1 doesn't support interlacing. Anyway, it's probably the low resolution and bitrate that make it look like crap to you, not the interlacing.
If you are willing to create nonstandard VCDs (XVCD), you can raise the vertical resolution to 480 and the bitrate by a fair amount. Has a huge benefit. (Still, use a deinterlace filter on your source video).
You could also create an SVCD, which uses MPEG2, which does support interlacing, and benefits from 480 vertical lines by default.
How can I know if Avi is progressive or interlaced ??
By apalace in forum Newbie / General discussionsReplies: 17Last Post: 8th Feb 2012, 14:20 -
Progressive Vs Interlaced?
By shagratt71 in forum Video ConversionReplies: 4Last Post: 26th Dec 2011, 09:22 -
de-interlaced means progressive ?
By codemaster in forum EditingReplies: 19Last Post: 23rd Dec 2010, 06:08 -
Interlaced or progressive
By rank in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jul 2010, 16:41 -
Progressive vs Interlaced Regarding Motion
By Brent212 in forum Newbie / General discussionsReplies: 6Last Post: 15th Jul 2009, 19:26
