I bought a pioneer 105 last week (have not flashed the firmware), finally burned a DVD-R disk with it, used Nero 55914, the media was Princo 1-4x, I choose test speed/simulation/write. It took 40 min, the disk will not work in my Pioneer 454 standalone player (cannot play disk on the screen) but it will work in my Pioneer 444 standalone player.
Can anyone offer a reason as to why it won't work on my 454?
I think that it depends on what software you use to burn your DVD.Pioneer dvd players don't seem to like disks burned by nero for some reason so I would suggest trying stomp recordnow max as my cousin now uses this to get his disks to play in his pioneer.What the difference is between your players is I don't know except that the different models probably have different firmware.Anyway try Stomp to see if it can get them to play on your 454.
Yo Boyle,
here's my method that makes a dvd that works on ALL stand alones!!
I've also got a Pioneer Dvr-a05...
1. Rip original DvD with DvD Decrypter
2. Do your stuff eg. transcaling with dvd2one/instantcopy/splitting
3. Use IfoEdit to update the VTS sectors for all the Video_TS*.* in the \VIDEO_TS folder, this is important!
4. Manually create an AUDIO_TS folder next to the VIDEO_TS folder
5. Burn with Nero 5.5.10.20 :
- Choose DVD-ROM (UDF/ISO)
- Choose ISO level 1
- Choose ISO9660
- Do NOT select Joliet
- Do NOT relax the ISO restrictions
- Use Physical Partition UDF v1.02
6. Burn the AUDIO_TS and VIDEO_TS folders in the root of the dvd and enjoy!
I've always had problems on SOME stand-alone dvd players with older versions of Nero but in this new version (v5.5.10.20) the guys at Ahead Software seem to have the problems fixed.
Now I can make everybody happy with my 'backup' dvd's
gr.
Remco"Drawn beyond the lines of reason. Push the envelope. Watch it bend." -
Pioneer DVD players seem to have some odd problems with files burned by Nero's older versions. Version 55.10.20 should work for you, or try Stomp Record Now Max and they should play ok on your burner.Originally Posted by Boyle
NERO Problem!!!
(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio
WQXR 96.3 FM classical music radio station moves to 105.9 FM, New York
By vhelp in forum Newbie / General discussionsReplies: 1Last Post: 8th Oct 2009, 22:16 -
edited material back to tape. Sony DCR-105.
By freelance in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 15th Nov 2008, 11:06 -
Pioneer 531H
By cscasto in forum DVD & Blu-ray RecordersReplies: 4Last Post: 6th Nov 2008, 21:19 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 07:02 -
Illegal Disc Error w/Pioneer DVR-105 in Nero
By Quadzilla in forum DVD & Blu-ray WritersReplies: 2Last Post: 20th Aug 2007, 13:23
