i am currently trying to copy dvd to dvd-r
if i copy onto 4 speed disk its fine but when i try to copy onto 1 speed disk i keep on getting power calibration error can anybody help me
only time i have seen that is when someone was writing too fast.
are you sure it was set to write at 1x.
thingimijig. -
This sounds like a media problem. I get the same error with CMC made discs (Khypermedia and Imation branded) in my Pioneer 105 burner. Try a better grade disc, Ritek G03, Taiyo Yuden and see if they work. Upgrading your firmware may also solve your problem.
Media or burning speed possibly being the issue are probably right, but upgrading your firmware may actually make your problem worse, depending on the firmware version. Pioneer has warned that upgrading to version 1.3 actually reduces the compatibility of some 1x media...
Check out this site:
http://www.pioneeraus.com.au/multimedia/dvdrrwfw.htm
Click on the "Update Information" button by the new v1.3 firmware download for the A05/105...
MBarrettMBarret
"Everything should be made as simple as possible, but not simpler." ...Albert Einstein
Pioneer DVR-530H:Cannot burn to DVD-Rs, works with DVD-RWs
By boba_dk in forum DVD & Blu-ray RecordersReplies: 33Last Post: 31st Jul 2015, 13:24 -
Pioneer DVD recorder
By cjones in forum Newbie / General discussionsReplies: 1Last Post: 11th Aug 2011, 07:14 -
A Pioneer DVD fix it problem
By kenmt in forum DVD & Blu-ray RecordersReplies: 6Last Post: 23rd Jul 2010, 09:03 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 07:02 -
Does Pioneer DVR-112D burn DVD+R and DVD+R DL media well?
By palmtree in forum DVD & Blu-ray WritersReplies: 26Last Post: 4th Jan 2008, 04:22
