Hi guys,
After deliberating for weeks about using Gordian Knot to encode DVDs to DivX, I've finally made the push and attempted to use it. Everything seems fine and work well after endless hours of trial and errors and time spent reading the online tuts available around.
Here are some background facts as to what software I'm using.
1) Gordian Knot Rip Pack v0.27
2) Gordian Knot System Pack v0.27
3) Replaced the VirtualDub withing the pack to v1.5.1
4) Instead Of Installing the Divx 5.0.2 Codec included in the packaged I'm using my own DivX 5.0.3 Pro Codec instead.
Besides the last 2 points I pretty much followed everything most of the tutorials online said except when it comes to the part before the actual encoding where I'm supposed to do a pass test I get this error, I simply ignored it and went ahead and did the encoding everything seems to work fine until the 2nd pass comes into play where I get 'roughly' the same error about not being able 'count encoded frames' again. Gordian does not halt and goes on encoding until I get a final avi file. The file seems fine so far. But I'm constantly bugged and nagged in my mind about this error that I can't seem to figure out. I'm just want to know whatever I can about what I'm messing with and Gordian Knot seems to be a pretty cool s/w that justifies me investing time in mastering it. Hope someone out there who has more expertise in this s/w can help me out here. It's driving me crazy
Here is an extract of the error:
7:08:44 PM: Started DivX5-First Pass: C:\PROGRA~1\GORDIA~1\LastCompCheck.avs
7:11:32 PM: Finished DivX5-First Pass. Duration: 2 minutes, 47 seconds.
7:11:32 PM: Trying to open Log-file.
7:11:32 PM: Error: Could not open _1_perc_D5_subs_SharpBicubic_704x528.log
7:11:32 PM: Error: Could not count encoded Frames.
7:11:32 PM: Speed: 0.000 Frames per Second.
7:11:32 PM: Done.
7:11:32 PM: Log File = _1_perc_D5_subs_SharpBicubic_704x528.log
Total Encoding Time: 2 minutes, 47 seconds.
Oh before I forget I have another question regarding the selection of audio tracks? Under the Interleaving & AVI-Overhead sub-section under the Bitrate tab.
Why do all the tutorials recommend the setting of a 1x vbr-mp3 of either 128kbps or 160kbps instead of the ac3 format which is ripped from the VOB file?
Which is of the better quality if any difference at all between ac3 or mp3 format? Is a preference of mp3 over ac3 a matter of compression (size) difference while the former not attributing much loss in actual quality or is it for some other unforseeable reason by me?
In the selection of mp3 bitrate what would be the optimal bitrate for retaining the best sound, would 128 be sufficient enough or would 160 be better and would 190 be an overkill?
Sorry if there's too much questions at one time.
Regards.
i think that error has do with divx 5.03.
did you just download gordian knot in the past few days?
they just updated it to work with 5.03,i think it was the 3rd of april.before then it doesn't work well with divx 5.03.
i haven't tried the updated gknot,since i'm staying with divx 5.02 pro at least untill they come out with a good ver.
that guide is setup for doing a rip with mp3 and having gknot doing the converting and joining of the audio.which most people do a rip with mp3.
i do my audio after the rip is done,but i do set up the bitrate and most of the time i get 2 perfect 700mb files when im all done.
ac3 is better then mp3 and the higher the bitrate the better,but the video is more important.
as for me i decide either mp3 or ac3 and the bitrate by looking at the number above the load button.(i dont do the test)
for 2cd try to keep the number under .300 so you give it a higher mp3 bitrate or the ac3 to lower the number.
Error with Auto Gordian Knot 2.55
By Salvus in forum Video ConversionReplies: 1Last Post: 2nd Nov 2009, 07:51 -
Auto Gordian Knot Hidden Options Error
By Mabbage in forum DVD RippingReplies: 1Last Post: 18th Aug 2008, 15:59 -
Auto Gordian Knot error issued by Virtual Dub
By loninappleton in forum Video ConversionReplies: 10Last Post: 30th Apr 2008, 12:56 -
"No adjustment is possible" error in Auto Gordian Knot
By rahul.never2far in forum Video ConversionReplies: 0Last Post: 20th Oct 2007, 09:40 -
Error in Gordian Knot when trying to load d2v
By php111 in forum DVD RippingReplies: 12Last Post: 5th Oct 2007, 22:32
