I have a Xvid movie (Treasure Planet) with bad audio sync. I will eventually convert it to SVCD but I was wondering if it can be dubbed and fix the audio to give to a friend as a Xvid. In virtual dub, there are no bad frames,
The video length is 1:35:32.774
The extracted audio length is 1:35:28.316 (read from CoolEdit)
Is it preferred to fix the sync before moving on to a SVCD conversion?
Mark
Results 1 to 1 of 1
how to fix audio out of sync in DVD !
By deejay.2001 in forum AudioReplies: 6Last Post: 23rd Jan 2012, 12:19 -
Is it possible to fix audio sync without reauthoring?
By likwid8 in forum Authoring (DVD)Replies: 4Last Post: 13th Nov 2011, 01:59 -
avi audio out of sync fix?
By the_shyguy in forum Newbie / General discussionsReplies: 7Last Post: 7th Jan 2009, 22:02 -
fix audio sync in dual audio avi
By jin007 in forum Newbie / General discussionsReplies: 2Last Post: 19th Jul 2008, 11:07 -
Audio is out of sync after using HDTV2DVD, how can I fix this?
By geek2330 in forum Newbie / General discussionsReplies: 20Last Post: 4th Oct 2007, 17:31
