ok i have this vcd i bought it will not work in my dvd player so i used nero to make a 1 on 1 copy then the other cd i copyed worked but it would not play all the way though without stoping and having to change to another part it broke it up into 3 AVSEQ.DAT files are they a way i can fix this without having to convert them to mpeg or merging them in tmpgenc or buring them again what program could i use to make them play all the way tho like cd clone will that multiplex make them play all the way tho without stoping does it joing them together why did it play on the cd i copied in nero? thanks
it sounds like its your dvd player not the disc if it keeps doing it with every disc. what kind of dvd player do you have? people should really fill out their computer details.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
its an APEX AD 1100w why does it show my movie in 3 or 4 parts? i have to change to each part after on part of the movie has finshed
i just look it up and you player seems to be able to play everything. what is this movie?
its something like an ufc tormament. i forgot the name of it my bro has it at his house right now its working great on his dvd player he has the GE from wally world
