I had been using the the trial version of IC7 and it worked great. I broke down and bought the boxed version this weekend from Office Depot.
I uninstalled the trial version and installed the retail version.
I ripped my dual layed DVD with dvddecrypter in file mode. I then opened IC7 and chose the HD option and located my IFO file and then opened it.
After that, I went to details to set to Customized resize. I then clicked start to get to the next screen to adust my disc size. Right after that the "preparing" screen shows for 1 second and then IC7 closes. No error messages.
Does anyone have any ideas?
Thanks!
I haven't had any problems keeping all settings to auto. I will sometimes tell it the type of DVD I'm using, but I don't play with any other settings.
Got it figured out.
In decrypter, I was choosing only the main movie in file mode. Of course I forgot that I had to choose edit>select all in file mode. I had not used IC7 for a month because I was waiting to buy the retail version and forgot. I got used to using dvd2one where you only need to choose the main movie files in v102.
Sorry to confuse.
Question about interlace problem
By jimdagys in forum Video ConversionReplies: 13Last Post: 19th Dec 2011, 12:40 -
Demuxing Question/Problem
By hizzy7 in forum Newbie / General discussionsReplies: 2Last Post: 28th Feb 2010, 11:28 -
Sound problem question
By mysts in forum ComputerReplies: 3Last Post: 20th Apr 2009, 15:13 -
Ghost problem and DriveImageXML question
By bevills1 in forum ComputerReplies: 4Last Post: 12th Mar 2009, 09:46 -
dvd flick problem question
By m-man in forum Authoring (DVD)Replies: 2Last Post: 20th Aug 2008, 20:17
