i need someone to give me one on one help to take a dvd and and burn it to a cd and watch it on my tv!
please, im a fast learner and have all the tools for it, just need some one on one help
i have msn, aol, icq, and yahoo msg,
thanks!
[/b]
Results 1 to 18 of 18
NateDoGG
<---CLICK ON THE GREEN BUTTON THAT SAYS DVD RIP.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
so with that guide it'll tell me how to take a dvd cd on my comp and copy it to a dvd r cd?
with everything, all the menus and all that
btw, with a dvd r disc can i put any type of video on it and play it on a dvd player?NateDoGG -
if the dvd is single layered, then you can. if its dual layered, you will have to get rid of some of the extras or reencode the video for it to fit. read a little, it won't hurt.
hold up, do you have a dvd burner?
no i dont have a dvd burner
but i have a dvd player and cd-rw on my comp
and those are the tools i need right?NateDoGG -
you can't burn dvd-rs with a cd drive. if that were true, why would people buy $300 dvd burners?
so with my cd burner and dvd player i cant copy dvds on dvd-r discs?
NateDoGG -
you can convert the dvd to fit on cds. most dvd players can play vcd/xvcd/svcd/cvd/xsvcd.
No.
DVD's & CD's look the same BUT are NOT the same.
Think of it as tape & records. they are not the same yet, you can transfer the record to the tape.
Try looking at this program. I'm not telling you to get it but, this is kinda what you want to do.
http://www.dvdxcopy.com/products_dcp.htm
There are other more cost effective ways to do it.Don't give in to DVD2ONE, that leads to the dark side. -
so can i take a dvd put it into vcd mode and then burn it and watch it on a dvd player?
do any of u guys have msn or somethin, it would be easier to talk over thatNateDoGG -
Conquest10- can i get ur email or msn or whatever so i can ask you some more questions that i have about this stuff
NateDoGG -
don't have msn. or any messenger.
Assuming you have (at least) a DVD rom to load the DVD on your comp. No CDR drive will be able to do that. -
he has a dvd drive. check his profile.
yes i have one, i'm getting help right now, so i think i'll be ok for now
thanks tho to everyone, very fast responses and help
thanks againNateDoGG
