I've been trying to encode this movie forever! I'm wanting to encode this xvid movie to a 23.976 svcd using TMPGEnc. Here is a picture of the info on this file. If you could give me detailed information on what YOU would do to encode this file it would help A LOT. Also, please include audio stripping details.
(sorry picture looks really bad)
picture didnt work. anyways here is the info from virtual dub.
Video stream
___________
frame size fps: 640x272, 23.976
# of frames (time): 126417 (1:27:52)
decompressor: Xvid MPEG-4 Codec
number of key frames: 1509
min\avg\max\total key frame size: 1903/16063/45444 (23672K)
min\avg\max\total delta frame size: 98/4903/34620 (598113K)
Audio stream
___________
sampling rate: 48000Hz
channels: 2 (stereo)
sample precision: 0-bit
compression: Fraunhofer IIS MPEG Layer-3 Codec
preload skew: 384 samples (0.02s)
# of frames: 219691
min\avg\max\total frame size: 96/408/768 -
TMPGEnc; Video Tab:Originally Posted by Frag
Stream type: MPEG-2 Video
Aspect ratio: 4:3 Display
Frame rate: 23.976 fps (internally 29.97 fps)
Rate control mode: Your choice, I would recommend 2-pass VBR(VBR)
VBV buffer size: 112
Profile & Level: Main Profile & Main Level (MP&ML)
Video format: NTSC
Encode mode: 3:2 pulldown when playback
YUV format: 4:2:0
DC component precision: 8 bits
Motion search precision: High quality (slow)
Hope That Helps!!!
:P
3:2 pulldown when playback:
This is used when you have a FILM source movie (23.976fps), to leave it 23.976fps but have your decoder play it back at 29.97fps (works great for ripping DVDs). When 3:2 pulldown is used it does this.. It takes four sequential video frames (A, B, C, D) from the FILM and are drawn on the video display as A1, A2, B1, B2, C1, C2, D1, D2, where the 1 or 2 represents the field number within the frame.
Hope That Helps!!!
:P
Use Virtualdub, load your Avi, select audio- full processing mode, audio compression- no compression, audio conversion- 44.1 KHz (VCD,SVCD) or 48 KHz (DVD), save wav.Originally Posted by Frag
If the audio is AC3 or you get a VBR warning then use Goldwave. Load your Avi then save.
Also, before doing anything, scan and remove bad frames with VDub!
8)
