i am trying to make a video with one of those sceenes that is of just a road but it is sped up so it looks like the cars and stuff are moving realy fast. any ideas, freeware prefrably, or ulead videostudio 6.
"Joe"
ko woh sitcwhde my kyeotps auornd
I know that Windows Movie Maker can speed up in exponents of 2 (2x, 4x, 8x, 16x, 32x) and you'll be able to save as a uncompressed AVI instead of wmv.
Bravoxena -
how how how, orginal or 2, i have 2. thanks you have got me started on the right track.
ko woh sitcwhde my kyeotps auornd -
I don't know if VideoStudio has the same feature, but Ulead MS Pro allows you to right-click on the video clip and the pop-up gives you an option to change the speed of the clip. You can also split the audio from the video clip if you don't want the audio to change.
Mike -
no sorry, pity, how do you do it in MS movie make 2?
Anything.............. i am desprate.
Ulead's VideoStudio 7 claims to have speed adjustment. You could either upgrade or maybe the trial version has enough functionality to do what you want. Hope this helps.
Mike -
thanks, i dont think they have an upgrade, they did for 5 to 6 though so hopefully they will soon, im gonna go look at those features
Is there any video card that can encode/convert video at lightning speed?
By johnharlin in forum Video ConversionReplies: 11Last Post: 17th Mar 2012, 15:27 -
How to speed up video conversion
By csc12345678 in forum Newbie / General discussionsReplies: 20Last Post: 15th Feb 2012, 00:43 -
How do I speed up my video to 10X speed?
By mileena in forum Newbie / General discussionsReplies: 9Last Post: 27th Aug 2010, 13:24 -
How do I speed up DVD video?
By whoisus in forum Newbie / General discussionsReplies: 10Last Post: 7th Jun 2010, 16:44 -
will a separate video card speed up video encoding?
By edong in forum ComputerReplies: 12Last Post: 21st Oct 2009, 17:37
