OK I am making backup of "Set it off".. It is a DVD9 and it has both Widescreen and Fullscreen on the DVD.. I used DVD Decrypter to rip all files off the DVD.. I used Power DVD to view the VOB's and removed the Widwscreen files "VTS_01_0.BUP, VTS_01_0.IFO, and all 4 VOB's"..
Now my question is do I just burn the VIDEO_TS folder with nero, or is there something I have to do before buring..
Also what is the best version of nero to be useing when buring DVD's? I hear many dif. things...
Thanks so much for the help!
Yes I am a newbie!!!
any of the last few releases of Nero work
it just depends how you set it up as you can do it different ways
DVDROM(UDF/ISO) 1.02 is more compatiable with older players but it depends on your standalone
nero burning guide -
Do I have to do anything to the other files since I removed those files before I burn the DVD?
Yes I am a newbie!!! -
DVD-RW and DVD+RW are definitely the way to go! that way you can get rid of any old backups you might not want later on. then you save on coasters as well!Originally Posted by Bob W
