  1. I'm trying to convert a DivX movie to DVD and I have had serious problems with audio sync. I've read tons of topics regarding sync issues but nothing seems to help, so:
    Instead of extracting the audio in VirtualDub I'm trying to use the same file for movie AND audio source.
    Now to the problem. In the project wizard the estimated filesize is 17GB.
    the wizard also tells me that the movie is 320 min, but the truth is that the movie is only 95 min. Why is TMPGEnc telling me this??
    The movie is NTSC 23,976fps if that can help.
    Is there any solution to this??
  2. You could possibly have a broken divx file. I believe that there are some guides that show you how you can fix your divx simply. I hope it helps!
    Bravoxena
