I just purchased a Dazzle capture device. It works great capturing vhs / tv stuff to avi. Also, can convert to Mpeg-1 for vcd and mpeg-2 for SVCD. I am trying to play vcds on a phillips dvd711 player (supposed to be CDR and CDRW capable). I have nero 4.0 burner software too. What file format do most dvd player read in (Ex. *.mpg or *.mpeg)?
Is there a directory structure that i need to create on my cdr's when I copy the data files over? Can I actually create vcd's that will play on my dvd player without downloading/buying new software? Any help in doing this without menus just using a standard data CDR or CDRw would be apprieciated! Thank you!
VCD does have a set file structure...you would need some authoring software (which you can find links to on this site)
which means...you will probably need to download some stuff.
(I use Nero 5.5 which does both VCD and SVCD) -
These guides describes how to capture with a Dazzle Card to make VCD or XVCD.
check the "how to" -author on the left menu :
How to make good looking VCDs using a Dazzle Capture Card
Hardware Capturing direct to VCD
How to make an XVCD with Dazzle, but without reencoding
Hardware Capturing direct to XVCD
Error creating VCD
By maruz in forum ffmpegX general discussionReplies: 4Last Post: 17th Oct 2009, 07:42 -
Creating menus
By Meriks in forum Authoring (DVD)Replies: 3Last Post: 10th Feb 2008, 16:11 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Creating (S)VCD Stills with Audio
By Cornucopia in forum User guidesReplies: 8Last Post: 4th Aug 2007, 13:05 -
HELP With Creating AVCD
By BinaryJustin in forum Authoring (VCD/SVCD)Replies: 1Last Post: 4th Aug 2007, 12:38
