When using TMPGEnc i can't load up the files. It sais file type unsuported. I did use GSpot and it said i had all the needed codexs. Can anyone help me?
If you have a XVID, then you need to raise the priority of the DirectShow module to 3 in the VFAPI plug-in section of TMPGEnc and the rest at least two numbers below that.
Divx Converter Problems
By Maritimer in forum Video ConversionReplies: 11Last Post: 18th Dec 2009, 13:00 -
Divx Plus HD problems
By ColinMorrison in forum Video ConversionReplies: 9Last Post: 2nd Nov 2009, 10:04 -
DivX Encoding Problems
By ftshark in forum DVD RippingReplies: 3Last Post: 7th Mar 2008, 11:30 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
DIVx to DVD problems
By ulm4lyf in forum Newbie / General discussionsReplies: 8Last Post: 17th Jul 2007, 00:26
