D/L'ed "Catch me if you can" as an avi file. I first tried converting to mpeg using TMPEGnc using the same file for video and audo and got NO SOUND. I then used both avi2wav and virtualdub to extract the wav file and went back to TMPEGnc using the wav for the audio source, I received sound but out of sync (made no difference which wav source I used, avi2wav or virtualbud)
HELP PLEASE
Usally if you save out the sound as a uncompressed wav with VirtualDub then us that as the audio source then this sync issue goes away. But That takes encoding time.
If it is the same off sync all the way through the clip (say 2 seconds ahead or behind)....then use TMPG mpeg tools to seperate audio from video and then clip the one thats ahead.....then multiplex back together. This usally take minutes....instead of hours. -
You're violating the forum rules by mentioning a movie that you pirated.
"Art is making something out of nothing and selling it." - Frank Zappa -
Although I used avi2wav for the first try, I wnet back and used virtualdub (uncompressed) for the 2nd try, and the sync actually seemed worse. I'm not sure what you mean at the end of your replay by "clipping"
To be honest, while I was doing all this converting, I was wondering how TMPEGnc merged the two seperate files so that they would be sync'ed.
As a newbie first class, I would appreciate more detailed instructions. I sure would hate giving up on avi files. It would also be great to know what the end file will be as you look to download various torrents.
Thanks,
AVI to DVD: help with audio sync problems
By tanglemac76 in forum MacReplies: 9Last Post: 23rd Dec 2010, 14:50 -
A/V sync problems with an AVI...
By takearushfan in forum Video ConversionReplies: 0Last Post: 17th Aug 2010, 17:41 -
sync problems with flv to avi
By cynikalhedonist in forum Video ConversionReplies: 5Last Post: 15th Jul 2010, 07:34 -
mpeg sync problems after importing dvd
By blubot in forum Newbie / General discussionsReplies: 5Last Post: 23rd Sep 2008, 11:31 -
Xvid AVI DVD Playback Audio Sync Problems
By lozza_c in forum Newbie / General discussionsReplies: 5Last Post: 8th Jun 2008, 08:38
