  1. hi everyone, I just bought a pack of 25DVD from PC club (in OK) and burned with my Sony 500A(2.0e) The first 4 dvd I either got them pausing (played on Samsung P-701) a little bit or skipping some frames. The most disturbed thing for me is Recordnow 4.56 keep rejecting my new blank DVD! it says that I need to put a blank one in ???!!!
    I tried many Discs but hopeless
    I did check the blank DVD by DVDinfo --> showing Sony 2x (generic).
    I am new in DVD but experenced in PC --> I don't think I did anything wrong, I use p4 1.5Gig / 256MB with some very basic burning softwares.
    thank so much, by the way I paied $29 for 25 DVDs at PC Club --> pretty expensive
  2. I am having that same problem. It used to work fine, now all the sudden, crap!
  3. Thats what my first Sony did before it went belly up and completely died.
  4. Always install the pxEngine update for RecordNow products and for BackupMyPC.
    Gives you more compatibility with new brands (media and drive)
    You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
