Hi I have MPEG 2 file 720x576, and when I am using Vidomi for conversion to DIVX, It keeps 720x576 output file size setting and so it gives me lower picture quality in ordere to fit all on 700 MB
How to change output file size format, lets say 352x288 and to have as result better quality
try Virtualdubmod that can handle mpeg2 files
then just apply a resise filter to your desired sizeInovate Don't imatate -
Hello Baldrik,
I downloaded Virtual Dub MPEG 2 and I have MP3 codec instaled, I can see it on the Audio Compression list-but when I select MP3 and hit Save as Avi-it say that can not compress audio-so what to do
2. And does bit rate calculator works with all Divx codec(5.02divx)
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 02:26 -
Batch convert ISO to AVI/Divx/MPEG
By extrememc in forum Newbie / General discussionsReplies: 1Last Post: 11th Jan 2010, 18:13 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
Command line method to convert MPEG-2 to Divx Home Theater Profile
By CLIjunkie in forum Video ConversionReplies: 15Last Post: 6th May 2008, 21:22 -
How to Convert 1280*720 DivX to a less dimensions DivX
By firas_hashim in forum Video ConversionReplies: 9Last Post: 27th Jun 2007, 08:33
