  1. This is very odd and i dont kow what i am doing wrong. When ever i make a vcd it skip contantly and id really blocky except for one vcd that i made. i ve tried writeing it atlow speeds aswell. I a, also using very capale disks speed wise.
  2. Member MaDmiZe's Avatar
    May 2002
    City of...Atlanta
    I am not sure we have enough info to help you....
    What are you using to view these VCDs with?
    Are you making standard VCD....and what is the source file from??
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Does it play OK on your PC? Have you tried another DVD player?
  4. im trying to play it on a panasonic dvd player
    i hae also tried on a RCA dvd player and the same problem occurs
  5. Member MaDmiZe's Avatar
    May 2002
    City of...Atlanta
    Half the Panasonics in the compatablity section here....say they dont play CDR but most play CDRW...look up your model and check it. Same with some RCAs
    If it plays on your computer DVD drive and works fine....it is the standalones compatability....not your VCD...or method used to create it.
    My friends Panasonic plays VCD but not CDR....so unless he has factory VCD it no use.
    He also has a High price dual scan Samsung that Plays VCD, SVCD and CDRs but all the VCDs I make play great on my APEX and skip like a maniac on his Samsung...I'll assume his Samsung only plays "standard" discs....but I aint got none of those.....
