Results 1 to 24 of 24
  1. i have tmpenc 2.53.35.130 i' m using it for a while now
    bu now something strange happend
    the doesnt insert rigth in the begin of the movie it goes well
    till somewhere in /at the end of movie sub r gone and somtimes they come back
    this all happend after i encoded a movie
    if play the movie before encoding the sub r oke
    so what can i do best now????
    settings >> directshow multi reader 7
    tmpgence project reader 2.53 7
    avi2opendml reader 5
    wave file reader 4
    avi vfw compat reader 3
    bmp/ppm/tga/jpg reader 3
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Que? I've never seen any way to add subtitles with TMPGEnc. Please explain your modus operandi in greater detail.
    /Mats
  3. Originally Posted by mats.hogberg
    /Mats
    modus operandi ???
    tmpgence subs help..!!!
    wave file reader 4
    i got vosub 2.23
    sldpack 3.1
    p3 100mhz
    512 mb
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Yes, I read your post. modus operandi=a method of operating
    I was trying to explain that you have to explain how you add subtitles with TMPGEnc, as I didn't know that was possible.
    /Mats
  5. From what I know, there is no way to add subtitles within TMPGEnc.
    You could either burn them into the video by frame serving through with vdub or create selectable subtitles with programs like subrip and mpg2mps or subrip,bbMPEG and winsubmux.
    If you are having problems right now, how are you trying to do it? Is it a avi file with subs rather than dvd?
  6. oke look when you install vobsub
    you automaticlly get the subs with the movie ( ofcourse gif the same name
    to the srt and avi
    when i start tmpgence vobsub pops up and while enconding you see the subs in tmpgence...
    but my problem is the the subs dont stay ..
    it worked before
  7. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Okay! I see. Never done it that way. The preffered method is to load the AVI in VirtualDub, use the textsub filter to add the subs, and then frame serve to TMPGEnc. I suggest you try that path. As far as I can see, this is not a TMPGEnc problem, but rather a DirectShow/VobSub problem.
    /Mats
  8. any one else please.....
  9. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    Would have suggested the virtual dub route, but it's not goode enough for you, obviously. I would have looked into it some more, but your post is rather hard to follow. apologies if English is not your first language, but if it is......
  10. it isnt my first language ...virtual takes to long..
    tmpgence just strat enconding yuo will see the green arrow in /on you systry..
    but my problem is that the subs dont stay
  11. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Not at all! You just frame serve from VDub (or AviSynth) to TMPGEnc, and the encoding time impact is zero. Believe me (us) - The VDub (or AviSynth) route is the one to use!
    /Mats
  12. Originally Posted by mats.hogberg
    /Mats
    i have tried it but nothing happend
    frameservermode
    non-a/v request 0
    number of frames served 0
    audio segments deliverd 0
    frameclients installed avifile only
  13. Originally Posted by mats.hogberg
    You really, really dislike reading guides, do you?
    How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
    /Mats
    frameserving the audio go out of sync ......
  14. I am currently encoding an avi to svcd and for the first time including sub titles. As usual I refer to these forums to glean tips etc. One post caught my attention and I believe I may have found what he was seeking.
    Dj_Rainaldo began this thread and was not clear on his method or his problem.
    I subsequently found this post, https://www.videohelp.com/forum/viewtopic.php?p=499888&highlight=srt#499888
    and what Dj_Rainaldo was saying began to makes sense.
    Basically he was/is:
    *using the VobSub filter ("the green arrow in the sys tray")
    *could see the subs as the movie played ("you automaticlly get the subs with the movie")
    *could see the subs as he was previewing with TmpgEnc ("when i start tmpgence vobsub pops up and while enconding you see the subs in tmpgence...")
    *has encoded subs successfully with TmpgEnc ("it worked before)
    *now is somehow losing the subs (but my problem is that the subs dont stay)
    I too am looking for an easier method, other than frameserving, that produces the desired results. I followed Baldricks advice and installed the latest VobSub 2.23 filter. In TmpgEnc my Directshow Multimedia File Reader is the highest priority on the list, set at 1. I can view the subs in preview.
    I will post my results after the encode completes. Hopefully all goes well and the subs are encoded throughout. If not, then I will be in the same boat as Dj_Rainaldo, looking for an answer! I do not know why he is having the problem that he is currently having. Hopefully I have shed a little more light on this and someone can add more input to help Dj_Rainaldo out.
    Stan
  15. Success. The .avi and .srt files were in the same directory, latest vobsub filter installed, TmpgEnc showed subs in preview, encoded SVCD has the subs. Thanks to Baldrick for his post. I saved a lot of time over frameserving etc.
  16. STan Thanks for explaining for me..
    I just reinstall every codec agian and even my " trustfully " tmpgenc
    And what do you know it works again
    I SOLVED IT a few Days ago ,
    cause no one was taking me seriues i didnt reply
    OJA I HAD 2 TMPGENC ON MY PC ..MAYBE THAT WAS THE problem
  17. Member scottb721's Avatar
    Oct 2002
    Australia
    Can this be done for DVD VOBs or the d2v output of DVD2AVI that gets used in TMPGE?
    How are people getting a movie as an avi that has a subtitle stream?
