hi please can someone hel me
i have downloaded a movie file in .rar i have used win rar to "unrar" it but i now have a .bin file how do i canvert this into a .avi or .mpg
the .bin is a ready to burn file containing the avi,mpeg, or whatever.
you could simply burn the bin to cdr. or
you can access the bin file with a program called isobuster and extract the file within. peace -
i apreciate ur reply but when i burn the .bin using nero i just get garbled stuff on my tv.
i have watched vcds from my dvd plyer before and they were perfect -
If you have the .cue file then tell your burn software to open the .cue file and burn it.
If you don't have the .cue file, then look for vcdgear from the Tools section on the left, download and install it. Use vcdgear to convert the bin file to mpg, then use Nero to create a vcd disk.
Hope this helps.
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
Video8 Conversion: Best trade-off for digital conversion ?
By ghl1 in forum Video ConversionReplies: 12Last Post: 6th Mar 2010, 18:36 -
bin files
By fredreed in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Nov 2009, 01:02 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 09:11 -
Bin file
By anton225 in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 13:05
