Hello:
Can anyone recommend a way to find the bad frames in a movie and fix them before the movie is encoded with TMPGENC?
I tried using virtualdub mp3 and video freeze and at the end it says that it has logged the bad frames. I just can't figure out where to go in virtual dub to find the bad frames????
Thanks,
Comet
Load the Video in Virtual Dub. Select Video-->Scan video stream for errors. The log will then tell you which frames are bad.
Hello. -
The log will be written to your C: drive. Look for the word "log" on any new files written to that drive after you have run your command.
Hello.
Premiere CS3 exporting bad frames
By spicediver10191 in forum EditingReplies: 4Last Post: 17th Apr 2012, 17:39 -
VirtualDub - fixing bad frames with blending and without re-encoding
By spicediver10191 in forum Video ConversionReplies: 3Last Post: 11th Apr 2012, 08:15 -
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 15:00 -
.avi file cannot be repaired - need to remove bad/corrupt frames
By realtechtalk in forum Video ConversionReplies: 0Last Post: 7th Sep 2008, 12:27 -
Cutting bad frames with VirtualDubMod
By lazaruz in forum EditingReplies: 2Last Post: 18th Sep 2007, 03:39
