  1. When running an avi file through virtual dub to determine what and if any bad frames are present..does anyone know where to look in virtual dub to get the beginning and ending of the bad frames so that they can be edited out?
  2. hi. this is how i delete bad frames from file. im not sure what versoin of vdub you are using but in vdub mod v.1.4.13.2 http://virtualdubmod.sourceforge.net/ i would load the file and click
    video/scan video stream for errors/improved scan
    let it do its thing then you have 3 optioins when its done and if it finds any
    video/scan video stram fro errors/ 1.show bad frames
    2.mask bad frames
    3.delete bad frames
    if you just want to delete the bad ones out select #3 and save your new avi.. thats it.
