I am having problems converting AVI to DVD, when using Tmpge I end up with two seperate files, sound/video yet my authoring progs Neodvd and Moviefactory wont let me input seperate sound/vid. If I try these progs to convert direct from AVI I get no sound
If you look at the choices to the bottom left under 'stream type' you can choose:
ES (video only)
ES (audio only)
ES (video+audio)
System (video only)
System (video+audio)
It appears that you have 'ES (video+audio)' selected. You can mux (check faq) the m2v and mp2 files together thou to generate a valid MPEG file (no need to re-encode).
To generate a MPEG file from the get go, choose 'System(video+audio)' (would normally be called PS) -
I have selected system video+audio but after loading file and starting conversion it still gives me 2 files sound/vid, and steram type tho greyed out has gone back to ES vid+sound
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 02:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 19:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
