I would like to cut parts of DVD (like songs) and store them on CD in DVD format. Don't know whether this can be acheived? I saw this link on ULead site - http://www.ulead.com/learning/vs/vs6_03_01.htm
I would like to rip the move with SmartRipper, convert it into MPEG2 with FlaskMPEG, cut the song with TMPGenc and burn it using SOME DVD authoring software. Is this possible? Is there any free DVD authoring software available?
Any suggestions? Thanks.
Remeber, you cant fit very much time on a CD. You may be better off doing a SVCD.
MiniDVD is the format you seek.
https://www.videohelp.com/miniDVDAC3/minidvdac3.htm
There is a guide. -
Rip with DVDx(free in Tools) and author and burn using Nero Vision Express(also free if you have Nero) to make a VCD.To make a miniDVD with a menu you will need MovieFactory.
