Hi there.
ok what I want to do is make a menu with mpeg layer 2 audio as the background menu with the phillips toolkit just like on a commercial vcd.
I converted a wav file to mpeg layer 2 file with a .mpa extension with TMPEGenc as stated in the guide, and then muxed the mpa audio file on its own with vcdmux without any problems, there were also no problems for vcd toolkit accepting the mmd audio file as the background music.
I builded and burned the image file. But when I put it in my dvd player, the menu plays for about 5 secs without audio and then a black screen appears and then my dvd timer starts from 0 secs to 1 minute (length of audio file) but I hear no sound. The menu works with audio on power dvd software on my computer perfect.
I selected file mode and opened the segment folder and I saw 2 segment files. when I select the 1st segment the menu appears without audio, but when I select the 2nd segment only the mpeg audio file plays. This is why many dvd players cannot play a menu+mpeg audio which are seperate segments.
When I load a segment from a commercial vcd with power dvd on my pc the main menu and the audio are in 1 segment and it starts to play, and the menu and audio of the commercial vcd play perfect on my standalone dvd player.
Can someone please tell me how to make a menu+mpeg 2 audio as 1 segment with the phillips toolkit. Thankyou.
Results 1 to 1 of 1
"Toolkit" for using a laptop to play video and audio onto a tv
By bobogs in forum Newbie / General discussionsReplies: 3Last Post: 24th Sep 2011, 20:49 -
Help:VDUB:CANNOT APPEND SEGMENT segment has a different number of streams
By lil_Dee in forum EditingReplies: 9Last Post: 23rd Jun 2009, 08:16 -
Phillips DVP642/37 help with DTS Audio problems
By cram_it_2000 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 24th Sep 2008, 14:29 -
Phillips DVP5982 vs Phillips DVP5992?
By jarko in forum DVD & Blu-ray PlayersReplies: 4Last Post: 12th Jul 2008, 12:41 -
Extracting jpg photos from the ITEM####.dat files in the VCD segment folder
By H-Man1953 in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2007, 06:54
