I am using Virtual Dub to join 2 DivX 5.02 files. The two frame rates do not match and so VDub won't let me join them. I tried setting the frame rate to be a constant value but then the audio was out of sync. What's the easiest way to join them?
Martyn1980 says this about joining AVIs that end up out of synch.:
If the audio goes out of sync then your using a VBR mp3 and have to select Full Processing in the audio tab, but thats a different story.Hello. -
I don't think my audio track is out of sync, but my video is. I just tried doing a full processing mode for both audio and video but the audio still does not sync with the video.
audio sync problem joining two avi files
By kthan in forum EditingReplies: 11Last Post: 2nd Apr 2011, 13:52 -
Problem joining (concatenating) avi's in virtualdub
By uart in forum EditingReplies: 6Last Post: 21st Nov 2008, 16:44 -
Joining avi's - problem with differing bitrates
By Topher5000 in forum EditingReplies: 6Last Post: 12th Aug 2007, 21:54 -
Audio Sync Problem Joining 2 AVI's Together from a 2 DVD Set
By boofer in forum EditingReplies: 6Last Post: 22nd Jul 2007, 02:29 -
Problem Joining AVI files with MEncoder
By RetSpec in forum EditingReplies: 1Last Post: 6th May 2007, 23:00
